Campus Switching and Routing
Is there a way to import a Cisco configuration into an Aruba s2500 switch?
Our district just got Aruba s2500's in and we were wondering, if there was a way we can easily use the configuration from our Cisco 3750 switches for the Aruba switches. We're planning on using a trunk port to go from the Cisco Switch to the Aruba switch as well.
Thanks!
Re: Is there a way to import a Cisco configuration into an Aruba s2500 switch?
The Aruba MAS configuration is profile based so you cannot import the configuration directly.
Some of the commands are similar though, for example:
interface vlan 10
ip address 10.1.1.1 255.255.255.0
no shut
show ip interface brief
show vlan
Tim Cappalli | Aruba Security
