Campus Switching and Routing
Occasional Contributor I
J9281B vs J9281D
can someone please tell me the difference between those 2 transcievers
J9281B vs J9281D and where I can use each one?
Re: J9281B vs J9281D
The B and D refer to the revision of the transceiver. Revision D products are backward compatible with the B (or A, C) revision.
When buying new DAC cables, I would get the revision D.
