Campus Switching and Routing
JL83A SPF-Module no LED not active
SFP module.JPGusing Direct Attached Cable, still not active
hi how to make these SFP module active i cant connect switch A to switch B and C...i am using DAC any body can help me here/ thank you!
Contributor I
Re: JL83A SPF-Module no LED not active
Hi, what are the P/N from the switches and the DACs cables?
If it helps please add Kudos
