Campus Switching and Routing
Occasional Contributor I
Jumbo Frames
I am setting up jumbo frames on my network(just for my SAN Vlan), and would like to know where to set mtu on s2500, VLAN, Interface or both? What would the effect be if if just set mtu on vlan only?  Interface only?
core is HP 8212zl with 10Gb fiber to  S2500
Thanks in advance
Contributor I
Re: Jumbo Frames
I think it should be configured both to work properly
