Campus Switching and Routing
Local Local Rudendancy - Users IP address issue
Hi ,
i have two controllers configured in with local local redundancy
the issue is
when Controller B fail , AP goes to Controller A  and users gets new IP address Normally.
but when controller B come back , Users holds IP  obtained from DHCP that is attached to controller A.
how can I fix it.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Local Local Rudendancy - Users IP address issue
Are you using HA? If yes, the access points should deauth the clients upon fail over, forcing them to get another opinion address...
i'm using LMS BackUp LMS
Raouf CHAHBOUNE
When using lms backup lms (older redundancy), the access point does not send deauths to the clients when it fails over, so it is expected that the clients are on the same vlan.  You could try turning on cpsec and see if it makes a difference...
