Campus Switching and Routing
Occasional Contributor I
MAB on aruba/HPE switch
I'm trying to get MAB to work on the switch running 16.03 version with ClearPass. I've done it many many times with cisco switches but I'm no clear on what configs are required on aruba switches. I've used the aes solution but still no luck.
Researched old HPE documentation and here is how a port is configured:
Global config on the switch
radius-server host key "xxxx"
radius-server host dyn-authorization
aaa port-access authenticator B9
aaa port-access mac-base B9
aaa port-access B9
aaa port-access B9 mixed
interface B9
   untagged vlan 499
   aaa port-access authenticator client-limit 5
   aaa port-access mac-based
   spanning-tree admin-edge-port
   spanning-tree bpdu-protection
Vlan 499 has an interface ip with a helper address of my clearpass for profiling (which is working fine).
My service has profiling enabled on it with [HPE bounce-host-port] as an action. The problem here is that the bounce host port take place but PoE is still there and the VoIP phone does not loos power. They still on the port with DHCP timed out.
Anyways, has anyone done MAB for VoIP with these switches and ClearPass? am I on the right track?
Re: MAB on aruba/HPE switch
My phones gets profiled but I don't see the [HPE bounce-host-port] getting triggered.
If I send coa to a client laptop to bounce the port, it works fine. but through the policy it is not happening.
