Campus Switching and Routing
Frequent Contributor I
MAS 3500 as router; DHCP ip helper?
We recently replaced our last locations hardware with an Aruba deployment. On most of our other sites we use an Alcatel OmniSwitch6900 for routing and the ip helper command is pretty straight forward.
I was reading some documentation on an AP controllers commands because I didn't have luck finding ip-helper documentation on the MAS series. But they don't seem to translate over to the MAS S3500 switch commands.
interface vlan 10
ip helper-address x.x.x.x
Comes up as an unrecognized command.
Are the MAS switches capable of DHCP helpers on vlans?
Re: MAS 3500 as router; DHCP ip helper?
Thank you! Not sure how I overlooked that. Got it working right away.
Thanks again.
