Campus Switching and Routing
Occasional Contributor I
MAS Certificate replacement
Hello
I have a few MAS switches and I am attempting to replace the default certificate following this guide:
http://www.arubanetworks.com/techdocs/ArubaOS_7_Web_Help/Default.htm#mas_guides/management_access/Managing_Certificates.htm#management_utilities_163792609_1117657
https://community.arubanetworks.com/t5/Wired-Networks/ArubaOS-Default-Certificate-Revocation-FAQ-Mobility-Access/ta-p/275815
I have generated the csr, signed it with my internal ca. The doecument doesnt state how to load it into the switch, i am just assuming tftp as I cannot access the webui for some reason which I will troubleshoot after I upgrade it soon.
I receive the following error when i try to import the signed csr using the following command:
(edge-sw-01) #crypto pki-import pem ServerCert edgesw01 edgesw01.cer
Error in importing file
It is definitley in the flash file system:
#dir
-rw-r--r-- 1 root root 1964 Jul 28 01:58 edgesw01.cer
I have tried as a windows txt and a unix txt (crlf vs lf), same issue.
it seems i can change the names to anything and the same error appears:
#crypto pki-import pem ServerCert asd asd
I have converted the pem to a der and it still doesnt work:
(edge-sw-01) #crypto pki-import der ServerCert edgesw01 edgesw01.cer
Error in cert format
Any ideas?
ACCP, ACMA, ACMP, ACDX
Re: MAS Certificate replacement
Updating the code and rebooting seems to have fixed the WebUI which has allowed me to upload a cert via the WebUI.
