Campus Switching and Routing
Trusted Contributor I
MAS: Configured MTU Isn't Displayed
I set the MTU to 1500 bytes on a port channel interface group, but noticed the MTU size was not reflected when I did a show interface port-channel #. The default MTU of 1514 was displayed.  I tried configuring the MTU on a physical port that is not a member of the port channel and the proper MTU was displayed.  Not sure if this is a cosmetic bug or how it's intended to work.  I'm seeing this on 7.3.0.1
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: MAS: Configured MTU Isn't Displayed
If you set it to 1486, what is displayed in the show output?
Tim Cappalli | Aruba Security
Contributor II
Hi "thecompnerd"
I tried with MTU ranging from 64 to 9216 (including 1500).
It reflects properly:
(MDF-2) (port-channel "1") #mtu 64
(MDF-2) (port-channel "1") #show interface port-channel 1 | include MTU
MTU 64 bytes
(MDF-2) (port-channel "1") #mtu 1486
MTU 1486 bytes
(MDF-2) (port-channel "1") #mtu 1500
MTU 1500 bytes
(MDF-2) (port-channel "1") #mtu 1514
MTU 1514 bytes
(MDF-2) (port-channel "1") #mtu 9216
MTU 9216 bytes
Above was tried with both static & lacp based port-channel interfaces, with 7.3.0.1.
rgds,
-Vinay
