Campus Switching and Routing
Trusted Contributor I
MAS: Source interface for logging
Is it possible to specificy a source interface for logging?  Have a MAS configured with multiple routed interfaces on it and can't figure out how to source from a specific interface.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: MAS: Source interface for logging
You can't currently set it. It is usually sourced from the lowest IP address.
Tim Cappalli | Aruba Security
That did the trick. Thanks!
