Campus Switching and Routing
Frequent Contributor II
MAS firmware upgrade
Hello - we are currently running firware version 7.4.0.3 on our mobility access switches. I see that there are two upgrades available, 7.4.1.0 and 7.4.1.1. Any suggestions/recommendations on which we should upgrade to? Can we go directly to 7.4.1.1, skipping 7.4.1.0?
Thanks.
Re: MAS firmware upgrade
Yes - you can go directly to 7.4.1.1
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Done.
