Campus Switching and Routing
Trusted Contributor I
MAS: remove all interface from interface group
Is there a good way to remove all interfaces from an interface group with one command?  "apply-to remove all" does not work.  You can do "apply-to remove 0/0/0-1/1/1" (ending in 1/1/1 assuming you have 2 stack members) but the command has to be entered twice as it clears the first stack member ports, but leaves behind the second stack member ports.  Any thoughts?  BTW, this is version 7.3.2.0.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Aruba
Re: MAS: remove all interface from interface group
Try "no apply-to".
Best regards,
Madani
Ah!  That never crossed my mind... thanks Madani.
Aruba
No prob. :)
