Campus Switching and Routing
MSM765 Activation
  1. We have to get an Activation ID, which first involves extracting the Hardware-ID from your new MSM765;
NOTE: The controller Service OS CLI is available once the controller Module Status LED stays on green.
  1. To obtain the activation hardware ID:
Change to the switch CLI configuration context:
config
  1. Launch the Service OS CLI:
Services <slot-id> 1
  1. Obtain and record the MSM765 zl Activation Hardware ID:
Licenses hardware-id activation
The Activation Hardware ID is displayed.  VERY IMPORTANT - Record this string precisely as displayed, including the dashes.
  1. Now TEC team will then generate an ACTIVATION-ID based on HARDWARE-ID.
Installing the Activation ID
The starting point for this procedure is the Service OS CLI prompt for the controller you are activating. (Services <slot-id> 1)
  1. Install the product license key:
Licenses install activation <license key>
Where <license key> is the product license key just provided by the My Networking portal. The key must be entered precisely as received including the dashe.
  1. Boot the controller product:
boot product
The boot image is verified.
  1. At prompt:
System will be rebooted. Do you want to continue [y/n]?
Respond with "y".
The product reboots.
VERIFICATION:
Now confirm the services with the below command:
SW01# services
                Installed Services
 Slot   Index Description                               Name
 B,D       1. Services zl Module                        services-module
 B,D       2. HP ProCurve MSM765 zl Int-Ctlr            msm765-application
