Campus Switching and Routing
Mobility Access Switch Aggregate different port speeds
Hello
I want to know if this is possible
Lets say you have 2 buildings
In each building you have 1 switch
We will be  doing a remote Stacking betweent both switches so even if the switches are located in differente buldings you see it as one switch
Let say on anoter building we have another switch.
We would like to do a link aggregation to those swithces, 1 port of 10G to one of them and maybe 3 ports of 1 gigas to the other swithc on the other building
It is possible to aggregate ports of differnets speeds in a link aggregation and have it active active so it use all the LAGG partners to send traffic as well?  And well also taking in mind that youa re having a remote Stacking.
Cheers
Carlos
Alternetworks Corp
Re: Mobility Access Switch Aggregate different port speeds
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thank you!!!
Alternetworks Corp
