Campus Switching and Routing
Mobility Access Switch for Cisco + Juniper Engineers - Part 1: Basic Configuration
The attached document is a cheat sheet / command conversion sheet for Cisco and Juniper engineers to provide command equivalents and configuration snippets for Aruba's Mobility Access Switching line.
All text is searchable.
This is part 1 which covers basic configuration.
If you think a command or configuration should be added, please let me know.
Hope it helps! Enjoy.
Coming soon:
Part 2: Troubleshooting commands
Part 3: Advanced Configuration
     - User authentication (AAA/RADIUS/Guest)
     - TACACS+ management access and authorization
PRINTING NOTES: Document is 8.5x14 (Legal)
Tim Cappalli | Aruba Security
Re: Mobility Access Switch for Cisco + Juniper Engineers - Part 1: Basic Configuration
This is awesome Tim!  Very nice work.  This should come in very handy for anyone that has a mix of switch vendors in their network or are interested in how the MAS products compare in terms of CLI.
Moderator
Sweet Tim :)
Best Regards
-d
ClearPass Product Manager
Frequent Contributor I
Show off! :-)
EDDIE FORERO | @HeyEddie
