Campus Switching and Routing
Frequent Contributor II
Mobility Access Switch lifespan?
With the advent of bringing HP switches into play, is there any plan of moving away from the mobility access switches? Or is their development going to be continued. I am looking at some S1500s or S2500 for a possible deployment but I do not want to necessarily go this route if I am looking at something that may soon be discontinued.
Any insight is appreciated!
Scott McNeil - Sr. Network & Security Engineer, Global Process Automation
Network+ | CWNA | CWTS | ACSP | ACMP | ACMA | BREC
Re: Mobility Access Switch lifespan?
You should position the new ArubaOS switching line (2930F, 2920, 3810M,
5400)
Tim Cappalli | Aruba Security
