Campus Switching and Routing
Frequent Contributor II
Mobility Access Switches - best practice for power shutdown
What's the recommended procedure for handling a planned power outage with regard to shutting down Aruba switches (we have S2500s and S3500s)? The power outage is scheduled to be a day-long operation, so relying on UPS battery back-up isn't a factor. I'm guessing just a configuration save and back-up is about all that can be done - correct?
Thanks for any information!
Jon Koelker
Oyster River School District
Aruba
Re: Mobility Access Switches - best practice for power shutdown
Yes, I would do a "write mem" and then issue a "halt". This will gracefully shutdown the switches.
Best regards,
Madani
Thanks, Madani. So to re-start the switch would you just disconnect and then re-connect the A/C power?
Aruba
Yup. Halt will shut them down (little RED shutdown LED will illuminate) and then to power them back up, you need to remove/add the power cable.
Great, thanks!
