Campus Switching and Routing
Occasional Contributor I
Mobility Controller USB modem
Is it possible to use a USB 4G modem as a backup link on a 7000 series mobility controller?
I've been going through the documentation and it points to this only be available on IAPs/RAPs but you have cellular options within Aruba-OS on the controllers so I'm a little confused?
Thanks.
Re: Mobility Controller USB modem
Yes.
The uplink manager controls this http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Adding_Local_Switches/UplinkManager.htm?Highlight=uplink manager
I read that but I think my confusion came with 'Uplink Type' field.  I wasn't sure if I needed to set this up or if I needed to type the cellular to a vlan.
Just so I understand, I create a cellular profile and the uplink manager handles the rest?  I don't have to apply the cellular profile to anything, set any routing, etc.?
Thanks for the reply.
