Campus Switching and Routing
Contributor II
Mobility Switch
I have a design question.  I have a customer that would like to install the Aruba switches in tunneled node.  However, they would like to have it where if the master controller failed it will just operate like a L2 switch.  Is this supported?  If so how would you go about programming such a setup?
Re: Mobility Switch
That is not currently supported.
You can have a backup controller configured or point the TN ports to a VRRP address of a controller pair.
Best regards,
Contributor II
Re: Mobility Switch
Okay. That is what I thought but before I told the customer no I wanted to check. Thank you for responding!
