Campus Switching and Routing
Monitoring 2930F switches
We are installing some 2930F switches in a customer environment, they want all of them to be monitored via SNMP. I haven't been able to download the MIBs for this switch.
Basically, I need to check CPU, memory utilization and environmental variables like fans and temperature, is it possible? I see that the command "show system temperature" doesn't exist, so I can't even check it via CLI.
Could anyone lend a hand here, please?
Re: Monitoring 2930F switches
Greetings!
SNMP MIBs can be downloaded from HPE Support (there's one MIB repository for the entire Aruba/HP switching lineup).  For the 2930F, that will cover CPU and memory utilization (as well as interface statistics and other common parameters); however, I do not believe this platform has (at present) environmental monitoring statistics accessible from either the CLI or SNMP.  I'll check with our team here to find out if there is any method of getting that info.
Matthew Fern | Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise Company
Hi Matthew
Thank you very much for the link, that will help a lot, I am still getting used to the HPE support website.
I'll try with those MIBs, I think it is what I needed.
Dan
