Campus Switching and Routing
Multicast to another VLAN
Hi there,
I just implemented a multicast server on my lab, here's the simple topology:
Multicast Server (VLAN 1) - Aruba 2930F (VLAN 1) - Sophos Firewall (VLAN 1) - Aruba 2930F (VLAN 1, VLAN 2) - Client (VLAN 2)
My problem is when i use VLAN 2 on client and stream multicast from the server, the client can't stream the video, but if i switch to vlan 1 the client can receive the video.
On each vlan i used igmp version 3.
When i check the igmp, vlan 2 already joined the multicast group but cant stream the video.
VLAN ID : 2
  VLAN Name : LAN AREA
  IGMP version : 3
  Querier Address [this switch] : 10.10.22.1
  Querier Port :
  Querier UpTime : 20h 15m 54s
  Querier Expiration Time : 0h 1m 5s
  Active Group Addresses Tracking Vers Mode Uptime   Expires
  239.1.22.2             Filter   3    EXC  0m 21s   4m 0s
  239.255.255.250        Filter   3    EXC  1h 1m    3m 21s
The reference i read, to forward multicast packet to another vlan theres must be a router with a multicast route, can the 2930F do that? as i know the 2930F is a L3 switch.
BR,
Prasetyadhi R.
Contributor I
Re: Multicast to another VLAN
The 2930F is a L3 switch which also support multicast-routing using PIM-SM or PIM-DM on 16 x L3 VLAN interfaces with 200 routes . Unfortunatly the manuals are missing this piece which is currently beeing looked after. Meanwhile take the 3810 "Multicast and Routing Guide".
