Campus Switching and Routing
Occasional Contributor I
NTP server problem
Hi all,
I am trying to launch Controller setup wizard. I don't use NTP server for time synchronization, just want to keep local time [see pictures 1 NTP].
But at the end of setup I have an error [see picture 2 error] that 'Cannot delete the NTP server', but NTP server has never been installed at all.
What You will suggest me to do?
Re: NTP server problem
I would either restart the wizard or put a dummy NTP server in ( is a good one, that you can even use if you have internet access).
After the wizard finishes, you can change/delete NTP again if you like under Configuration -> Management -> Clock.
