Campus Switching and Routing
kmd
Contributor II
Need help converting 3Com Baseline Switch 2928-HPWR Plus config for S1500-24P
Hi.
I have several new S1500-24P switches to configure. I have been sitting on them for a while, because I have very little experience in configuring switches, and no experience with MAS. I've tried to look for training videos to assist me in their configuration, but I can't seem to find anything. The swicthces configurations will essentially be the same.
Is there an easy way to import the 2928-HPWR Plus config (attached)?
Or if someone is bored and wants to work it for me, I'd appreciate the help. I am at a total loss.
Thank you.
Trusted Contributor I
Re: Need help converting 3Com Baseline Switch 2928-HPWR Plus config for S1500-24P
there were training videos at one point, anyone have a link?
kmd
Contributor II
Hi Boneyard.
I reached out to the Aruba Training Team. They told me that there will be training classes this summer. I inquired about videos. They said videos will be a part of that. Not the answer I was looking for. $$
I can find Cisco videos all over the place on Youtube. But, no basic vlan and trunking videos for Aruba. Maybe I haven't looked hard enough.
Thanks!
This should help you get started:
hostname 300wLan
clock timezone EST -5
vlan 100
vlan 101
vlan 200
vlan 201
vlan 300
vlan 301
vlan 400
vlan 401
mgmt-user admin root
spanning-tree
interface vlan 1
ip address 10.1.10.63 255.0.0.0
interface-profile switching-profile "EDGE-PORT-TRUNK"
switchport-mode trunk
native-vlan 1
trunk allowed vlan 101-101,200-201,300-301,400-401
interface-profile poe-profile "POE-ENABLE"
enable
interface-group gigabitethernet "EDGE-PORTS"
apply-to 0/0/0-0/0/23
poe-profile POE-ENABLE
switching-profile EDGE-PORT-TRUNK
lldp-profile "lldp-factory-initial"
trusted port
interface port-channel 1
port-channel-members 0/1/0,0/1/1
Tim Cappalli | Aruba Security
kmd
Contributor II
Thank you very much, Tim
