Campus Switching and Routing
New Aruba Switch Environment Configuration Help
Hello all,
Like many I am new to Aruba (HPE) switching but have worked with Cisco switching for the past 15 years. I have setup my configuration and everything seems to be working in the test environment.
I wondered if someone with more HPE switching experience than me could look over the configuration and let me know if the configs look ok?
I have attached a network diagram and IP's have been changed to protect the innocent.
Here is the inventory of what i am configuring.
Core Switch - Aruba 3810M 16SFP 2 Slot with 1 expansion SFP Installed.
Access Switches - 10 Aruba 2530-48G 2SFP.
All 2530 will connect to the 3810 with a 10GB DAC cable.
Most all ports on the 2530's will be on VLAN10 in the configuration with a couple exceptions.
Core Config
hostname "core1"
module 1 type jl075x
module 2 type jl075y
module 3 type jl075z
flexible-module A type JL083A
telnet-server listen data
web-management listen data
ip ssh listen data
ip route 0.0.0.0 0.0.0.0 10.2.2.2
ip route 10.200.1.0 255.255.255.0 172.1.2.2
ip route 10.201.1.0 255.255.255.0 172.1.2.2
ip route 10.202.1.0 255.255.255.0 172.1.2.2
ip routing
snmp-server community "public" unrestricted
snmp-server listen data
oobm
disable
no ip address
exit
vlan 1
name "DEFAULT_VLAN"
no untagged 1-16,A1-A2
untagged A3-A4
no ip address
exit
vlan 2
name "mgmt"
tagged 1-16
ip address 10.1.1.250 255.255.255.0
exit
vlan 7
name "wifi"
ip address 10.7.1.1 255.255.255.0
exit
vlan 10
name "access"
tagged 1-16
ip address 10.20.1.1 255.255.254.0
exit
vlan 30
name "main"
tagged 1-16
ip address 10.30.1.1 255.255.255.0
exit
vlan 40
name "staff"
tagged 1-16
ip address 10.40.1.1 255.255.255.0
exit
vlan 172
name "wan"
untagged A2
ip address 172.1.1.1 255.255.255.252
exit
vlan 254
name "secure"
untagged A1
ip address 10.2.2.2 255.255.255.252
exit
primary-vlan 2
no tftp server
tftp server listen data
no autorun
no dhcp config-file-update
no dhcp image-file-update
password manager
password operator
Access Switch 1 thru 10 Config. All that will change is hostname and management IP.
hostname "access01"
ip default-gateway 10.1.1.250
vlan 1
name "DEFAULT_VLAN"
no untagged 1-48,50
untagged 49
no ip address
exit
vlan 2
name "mgmt"
tagged 50
ip address 10.1.1.221 255.255.255.0
exit
vlan 10
name "access"
untagged 1-48
tagged 50
no ip address
exit
primary-vlan 2
