Campus Switching and Routing
Jed
Not Seeing 10 GIg interfaces on 2930M switch
I am not seeing the 4 10 gig interfaces on my 2930M switch. Do i have to activate something to get these interfaces to show up?
Aruba_Access_01# show module
 Status and Counters - Module Information
  Chassis: 2930M-24G-PoE+  JL320A         Serial Number:   SG76JQL0V4
  Slot  Module Description                         Serial Number    Status
Aruba_Access_01# show int status
  Port     Name       Status  Config-mode   Speed    Type       Tagged Untagged
  1                   Down    Auto          1000FDx  100/1000T  No     1
  2                   Down    Auto          1000FDx  100/1000T  No     1
  3                   Down    Auto          1000FDx  100/1000T  No     1
  4                   Down    Auto          1000FDx  100/1000T  No     1
  5                   Down    Auto          1000FDx  100/1000T  No     1
  6                   Down    Auto          1000FDx  100/1000T  No     1
  7                   Down    Auto          1000FDx  100/1000T  No     1
  8                   Down    Auto          1000FDx  100/1000T  No     1
  9                   Down    Auto          1000FDx  100/1000T  No     1
  10                  Down    Auto          1000FDx  100/1000T  No     1
  11                  Down    Auto          1000FDx  100/1000T  No     1
  12                  Down    Auto          1000FDx  100/1000T  No     1
  13                  Down    Auto          1000FDx  100/1000T  No     1
  14                  Down    Auto          1000FDx  100/1000T  No     1
  15                  Down    Auto          1000FDx  100/1000T  No     1
  16                  Down    Auto          1000FDx  100/1000T  No     1
  17                  Down    Auto          1000FDx  100/1000T  No     1
  18                  Down    Auto          1000FDx  100/1000T  No     1
  19                  Down    Auto          1000FDx  100/1000T  No     1
  20                  Down    Auto          1000FDx  100/1000T  No     1
  21                  Down    Auto          1000FDx  100/1000T  No     1
  22                  Down    Auto          1000FDx  100/1000T  No     1
  23                  Down    Auto          1000FDx  100/1000T  No     1
  24                  Down                                      No     1
Aruba_Access_01#
New Member
Re: Not Seeing 10 GIg interfaces on 2930M switch
What's the part number of the module you have installed?
Jed
Hi Scott,
This is a 1U unit. The interfaces are interfaces that are on the front of the unit and are integrated into the unit. There is not module that is replacable.
from the Quickspecs... your Switch(JL320A) doesn't have 10G.
But there are Modules you can add at the back of the Switch:
Aruba 2930M Switch Series accessories
Modules
Aruba 2930 2-port Stacking Module JL325A
Aruba 3810M/2930M 1-port QSFP+ 40GbE Module JL078A
Aruba 3810M/2930M 4-port 100M/1G/10G SFP+ MACsec Module JL083A
Aruba 3810M 4 HPE Smart Rate PoE+ Module JL081A
hth
Alex
Jed
There are 4 SFP ports on the front of the switch. How do i get these to show up in software so that i can configure them.20170920_090609.jpg
21 to 24 are dual personality, if there is a SFP it shows up in the "sh int brief", as in your output.
But this SFPs must be supported to give you more information and 10G isn't supported, as these are only SFP and not SFP+ Ports!
This SFPs are supported:
HPE X111 100M SFP LC FX Transceiver J9054C
HPE X121 1G SFP LC SX Transceiver J4858C
HPE X121 1G SFP LC LX Transceiver J4859C
HPE X121 1G SFP LC LH Transceiver J4860C
HPE X121 1G SFP RJ45 T Transceiver J8177C
HPE X122 1G SFP LC BX-D Transceiver J9142B
HPE X122 1G SFP LC BX-U Transceiver J9143B
hth
Alex
