Campus Switching and Routing
Super Contributor II
Not able to delete spanning tree commands
Hi guys,
Today I was doing some configuration with two 3810M switches in stack for testing. I enabled spanning tree and assign priority 0, but after a while a disabled spanning tree. But there are some commands that remain which are "spanning-tree priority 0" and "spanning-tree Trk1 priority 4" (the latter appeared after I configured a trunk, I don't know the reason). I issued commands like "no spanning-tree" or "spanning-tree disable" but the commands still remain. I have tried with the commands "no spanning-tree priority" or "no spanning-tree Trk" but they don't exist. I have also enable spanning tree and disable once more, with the same result.
What can I do? How can I get rid of them? I have attached some output.
Thanks in advance,
Julián
Re: Not able to delete spanning tree commands
Hi guys,
Any idea?
Julián
Contributor II
I believe these settings will not be removed. But they will have no effect if STP is disabled.
|ATP FLEXNETWORK V3|ACSA
Hi John,
Looking at other post I have found that these commands can be removed returning to their default values, which are:
spanning-tree Trk1 priority 8
spanning-tree priority 8
I have typed this and the commands were removed.
Julián
