Campus Switching and Routing
Not able to enable Multicast Routing on 2930F
Running firmware 16.05.0004 on a JL259A
sw# config
sw(config)# ip multicast-routing
Invalid input: multicast-routing
What am I doing wrong?
Re: Not able to enable Multicast Routing on 2930F
Greetings!
The command should be present in the global configuration context; when you type 'ip' and then a question mark to show possible config parameters, what do you see?
MATTHEW FERN – TECHNICAL MARKETING ENGINEER, WIRED INTELLIGENT EDGE
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com
Thank you.
It turns out my switch was running from the secondary image (older firmware)
Everything is running OK after forcing the swicth to boot from the primary image (16.05.0004)
Thanks again.
