Campus Switching and Routing
Occasional Contributor I
One HP smart rate technology and Cisco Mgig
Hi Airheads Community,
I would like to clarify some thing regarding wave 2:
1. if we use Aruba AP 325 (wave 2) and connect it to non Mgig switch, would be able to maximize the 2.5 Gbps? or still 1G (2G if we aggregate) since Aruba AP 325 has no smart rate port?
2. If we use Aruba AP 335 (wave 2 and has smart rate port), does it have intervendor compatibility with CISCO 3650 MGIG switch? I mean, would we be able to maximize wave 2 technology (2.5 Gbps) without link aggregation?
Thank you very much!
-Ian
Re: One HP smart rate technology and Cisco Mgig
1) 325 has dual GigE so you wouldn't be able get
2) 335 can use multigigabit interfaces on eth0
Tim Cappalli | Aruba Security
Hi Capalli,
I was a bit lost there..
1. You mean, since AP 325 only have (2) 1G ports, even if we aggregate it, we won't be able to maximize Wave 2 (2.5 Gbps)?
2. Yes AP 335 have smart rate ports. What I want to know is if it's compatible with CISCO 3650 multi gig switch? Would be able to achieve speed of wave 2 2.5 Gbps)?
Thanks!
-Ian
1) you can still utilize Wave 2 technology, yes.
2) Yes
Thanks capalli..just want to be more sure/specific
1. can utlilize wave 2 technology but limited up tp 2G (gig aggregation) speed only. Right?
2. Yes - does cisco and aruba use the same technology?
1) yes but you'll never see speeds that high. There are too many other environmental variables.
2) Yes, it's an open standard.
