Campus Switching and Routing
Contributor II
PROBLEM BOOT MAS S2500
Hi
I have a brand new swtich and it reboot at "n" minutes. i attached the serial cable to my laptop and i see this message..
Anyone knows how can i troubleshoot this? and fix it?
CPBoot 1.0.35.0 (build 33583)
Built: 2012-05-08 at 00:36:42
1024MB DRAM init, XLS CPU, 64bit channel pair mode
DDR2 DRAM running at 533Mhz
DRAM:  Total = (0x40000000) 1024 MB
POST:  Memory test: Physical 0x00000000 - 0x10000000 - quick test
       Memory test: Physical 0x10000000 - 0x40000000 - quick test
       PASS
CPBoot 1.0.34.0 (build 32670)
Built: 2012-03-06 at 02:43:16
mtest_quick error: at:7ffffffe expect:2 , read:0
       FAIL
       PASS
Contributor II
Re: PROBLEM BOOT MAS S2500
i have more messages about this issue...
mtest_quick error: at:7ffffffd expect:1 , read:0
mtest_quick error: at:7ffffffe expect:2 , read:ff
mtest_quick error: at:80000000 expect:4 , read:0
mtest_quick error: at:80000004 expect:8 , read:ff
mtest_quick error: at:8000000c expect:10 , read:ff
mtest_quick error: at:8000fffc expect:10000 , read:ff
mtest_quick error: at:8001fffc expect:20000 , read:0
mtest_quick error: at:8003fffc expect:40000 , read:0
mtest_quick error: at:8007fffc expect:80000 , read:0
mtest_quick error: at:800ffffc expect:100000 , read:0
mtest_quick error: at:801ffffc expect:200000 , read:0
mtest_quick error: at:803ffffc expect:400000 , read:0
mtest_quick error: at:807ffffc expect:800000 , read:0
mtest_quick error: at:80fffffc expect:1000000 , read:0
mtest_quick error: at:81fffffc expect:2000000 , read:0
mtest_quick error: at:83fffffc expect:4000000 , read:0
mtest_quick error: at:87fffffc expect:8000000 , read:0
mtest_quick error: at:fffffffd expect:1 , read:0
mtest_quick error: at:fffffffe expect:2 , read:ff
mtest_quick error: at:0 expect:4 , read:0
mtest_quick error: at:4 expect:8 , read:ff
mtest_quick error: at:c expect:10 , read:ff
mtest_quick error: at:fffc expect:10000 , read:ff00
mtest_quick error: at:1fffc expect:20000 , read:ff00
mtest_quick error: at:3fffc expect:40000 , read:0
mtest_quick error: at:7fffc expect:80000 , read:0
mtest_quick error: at:ffffc expect:100000 , read:0
mtest_quick error: at:1ffffc expect:200000 , read:0
mtest_quick error: at:3ffffc expect:400000 , read:0
mtest_quick error: at:7ffffc expect:800000 , read:0
mtest_quick error: at:fffffc expect:1000000 , read:0
mtest_quick error: at:1fffffc expect:2000000 , read:0
mtest_quick error: at:3fffffc expect:4000000 , read:0
mtest_quick error: at:7fffffc expect:8000000 , read:0
mtest_quick error: at:ffffffc expect:10000000 , read:0
       FAIL
AND THE REBOOT AGAIN... :mansad:
Aruba
It looks like a possible hardware problem. I recommend you open a support case.
Best regards,
Madani
