Campus Switching and Routing
PXE Boot and Aruba MAS
I have weird issues with PXE boot not working with Aruba Switches when spanning-tree is enabled. It will fail even if portfast is enabled. Has anyone ever experienced this issue and if so is there any other resolution to it other than disabling spanning tree?
Super Contributor I
Re: PXE Boot and Aruba MAS
I've never had issues as long as portfast is enabled. You might want to put in a TAC ticket.
ACDX #419 | ACMP |
This issue was resolved by upgrading.
Trusted Contributor I
thanks for providing the feedback.
