Campus Switching and Routing
sr
Policy Based Routing with AOS8
Dear all,
We are using controllers in standalone mode with firmware 8.0.1.1 (latest AOS8 release).
These controllers are connected to multiple gateways. We would like to do Policy Based Routing (PBR) to associate some user roles with some specific gateway (and not the default one).
I have found an article explaining how to do it: https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-bind-a-router-ACL-to-user-role-for-implementing-PBR/ta-p/234522
But when done on AOS8, the PBR doesn't work, the packet are still sent to the default gateway.
Here are the commands used:
ip nexthop-list my-list
    ip 10.10.16.1 priority 1
exit
ip access-list route my-acl
    network 10.10.128.0 255.255.128.0 any any route next-hop-list my-list
exit
routing-policy-map role my-role access-list my-acl
I have tries to apply the acl to different roles (unauthenticated, authenticated), but it doesn't seem to work.
Sebastien
MVP
Re: Policy Based Routing with AOS8
Hi Sebastien,
why do you need PBR?
If you have different roles and they're in different VLAN's you will get the default gateway via DHCP.
Regards
Borja
Borja
ACMX #567 //ACCP//CWNA
sr
Dear Borja,
Changing the gateway in the DHCP isn't possible as the controller is acting as the DHCP server but also as a gateway (router) for the users.
Sebastien
sr
The underlying question is also: does the "routing-policy-map" mechanism still work with AOS8?
sr
Nobody knows if "routing-policy-map" is working and how to use it with AOS8?
PBR is supported in AOS 8.0. Weird that it's not working. I would advise you to open a case with support.
Thanks.
S.
