Campus Switching and Routing
Contributor II
Policy based routing on Aruba 5406R zl2
Can anyone please guide me how to configure Policy based routing on Aruba modular switch? I am new to Aruba networking.
I have the attached scenario, where I have 2 routers each configured with subinterfaces and I want to route some VLANs from R1 and the other VLANs from R2. Also note that on R2 I have configured a DHCP server for each VLAN.
The currently running version is KB.16.01.0006 and as I've read, that this version supports PBR without license.
Please I need support
Re: Policy based routing on Aruba 5406R zl2
I just created an eample that is based on your drawing from top of my head. Please test this in test infrastructure first since it's really from top of my head 8-). There are so many different options you can use within the classifier's or PBR actions. If you want to read some more information see the Advanced Traffic Management Guide manual and than chapter Classifier based software configuration. I'm assuming you have at least 5400 with V2 modules or higher. Hope this example will help you! Regards, Dobias
class ipv4 R1
match ip 10.128.0.1 0.0.0.255 any
match ip :10.144.0.1 0.0.15.255 any
class ipv4 R2
match ip 10.20.0.1 0.0.15.255 any
match ip 10.30.0.1 0.0.0.255 any
policy pbr R1_R2
class ipv4 R1
action ip next-hop <IP of default Gateway>
class ipv4 R2
vlan 15
service-policy R1_R2 in
Contributor II
Hi Dobias,
Thanks for your support.
I was reading some articles and found that PBR only works on inbound traffic, but in my scenario all edge switches are connected to the Core switch.
In the example you gave me, what do you mean by VLAN 15?
VLAN 15 was just the incoming VLAN I connected the PBR policy to.
