Campus Switching and Routing
Regular Contributor II
Port Security on the MAS Switches to prevent Rogue AP functionality
Hello All,
Is there any Security feature built into the MAS Switch to prevent Rogue Access Points terminating on a Physical Port from functioning?
Aruba
Re: Port Security on the MAS Switches to prevent Rogue AP functionality
There is a rogue AP enforcement feature between Instant APs and the Mobility Access Switch. When an IAP detects a Rogue AP, it can signal the Mobility Access Switch to search through it's MAC-Address-Table for the Rogue in question. When it is found it will shutdown the port if it is an access port or discard packets from that MAC address if it is found on a trunk.
We are investigating adding the same capability to Campus APs. If you have think this would be beneficial, I highly recommend submitting the request to the idea portal.
https://arubanetworkskb.secure.force.com/cp/ideas/ideaList.apexp
Best regards,
Madani
Thx Madani.
