Campus Switching and Routing
Frequent Contributor I
Preemption in MAS stack
We have a stack of S3500 switches in all our branch offices. The stack is configured manually like this:
stack-profile
   member-id 0 serial-number "XXXXXXXX" role primary-capable
   member-id 1 serial-number "YYYYYYYY" role primary-capable
   member-id 2 serial-number "ZZZZZZZZ" role line-card
When a failure occurs on member-id 0 (which is normally the primary switch) the primary role moves to member-id 1. When member-id 0 comes back online there is currently no preemption so the primary role stays with member-id 1. Is there any way of changing this?
Trusted Contributor I
Re: Preemption in MAS stack
Not that I've seen.
I used to be concerned about sm0 always being primary, but I stopped caring after realizing it didn't matter (in our environment).
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
For us it matters because we use Airwave to configure these switches, and when the secondary becomes the master the stack is "monitor only" in Airwave and will not get config changes.
Interesting.  Our MAS are not managed so I've never come across that.
Have you called TAC for a solution?  I'd be interested to know what they say.
