Campus Switching and Routing
Preventing users to use static ip address
Is enforce dhcp  feature available on aruba os swithces? its available on aruba controller
We have a client which have a issue that sometimes students put static ip address on wired machines for some reason and someitmes it seems they put the default gateway and it creates a network issue.
The dhcp enforment would fit here if i could apply it per port but im not sure if thats is available on aruba os switches.
Also if anyone got an idea to prevent this its welcome.
Cheers
CArlos
Alternetworks Corp
Re: Preventing users to use static ip address
guest the enforce dhcp wont work as i bealive it need some method of authentication  and there is no method of authentication
Anyways anyone got any idea?
Alternetworks Corp
