Campus Switching and Routing
Problem about AP and Huawei switche
Our company have a Huawei switch, which is a 10 Gigabit switch, Aruba IAP 6, they are connected to the 1-6 port respectively.Set up two SSID on AP1,
Two SSIDs are established on AP1, corresponding to VLAN 9 and VLAN 200 respectively. Port 1 connected to the switch is changed to a trunk port and all VLANs are allowed to pass through. During the test time, establish an SSID which belongs tp VLAN9, restart the equipment, the pc connect to the SSID can get the correct address, but here comes a question is that I found AP1 itself can not get the address, and can't be managed.
Can anyone can help me with this?
Thanks in advance!
