Campus Switching and Routing
Frequent Contributor I
Procdure to replace a switch in a stack
Could somebody explain to me or share a link that explains the procedure to replace a defective switch in a stack?
Re: Procdure to replace a switch in a stack
Are you using preset stack topology or relying on the election process?
Tim Cappalli | Aruba Security
We've changed the election priority on the different switches manually.
Please take a look at the procedure here: (you'll find the preset stack information about halfway down)
http://www.arubanetworks.com/techdocs/ArubaOS_73_Web_Help/Default.htm#mas_guides/aruba_stack/Stack_Member_Replacement.htm%3FTocPath%3DArubaStack%7C_____7
Thanks cappalli, exactly what I needed. (Now I feel sheepish due to the fact that it was in the user guide...)
