Campus Switching and Routing
Question: Is there a way to control the Aruba S1500 Switch via SNMP?
i wanted to control my S1500 Switch via SNMP but i only get this error message: SET failed.INFORMATION: No Access
when i enter snmp-server ? on the cli there are only this options.
community               set read-only community string
context                 Create/Delete a context apart from default
enable                  Enable SNMP Traps
engine-id               Engine ID of SNMP server in HEX.
group                   Define a User Security Model group
host                    Specify host address to receive SNMP notifications.
inform                  SNMP Inform parameters
trap                    SNMP Trap parameters
user                    User Name configuration for the USM security model
view                    Define an SNMPv3 MIB view
So is there a way to control my S1500 Switch via SNMP? Or what have i done wrong..
Thanks!!
Aruba
Re: Question: Is there a way to control the Aruba S1500 Switch via SNMP?
mhrdy,
The Mobility Access Switches, like the Mobility Controllers do not support SNMP Write access.
Best regards,
Madani
This are bad news :(
Does the S2500 or S3500 switch support SNMP Write Access ?
Thanks a lot!
Aruba
No Mobility Access Switch (S1500, S2500, S3500) supports SNMP Write and there are no plans to support it. Same is true of Mobility Controllers too.
Best regards,
Madani
Frequent Contributor II
Oh, that is remarkable. It is very common for switching vendors to support SNMP write. This can be very useful in use cases like:
- Enable/disable a certain port via SNMP
- Enable/disable PoE for a certain port via SNMP
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
