Campus Switching and Routing
REST Api in aruba stacked switches
Hello Everyone, Just wondering.
are all Aruba switches compatible with the REST Api when they are stacked?
I ask, because we are about to buy some 2930m switches for stacking
and I wonder if the Api is comptaible with them.
and well... I have been reading through some documentation....
and this is not very clear.
In september the documentation says that the APi just doesnt work in
3800 stacked switches
But in January 2017 it says that the Api just dosent work at all in all switches while being stacked
is there any way to be certain about this?
Reggards Eliot
Re: REST Api in aruba stacked switches
Hi Eliot,
Since release WC 16.04.008 (2930F/M) and KB.16.04.0008 (3810M/5400R) management of stacks of switches via REST API's are supported. This counts for backplane stacks and VSF (front plane).
Hope you'll find this anwser useful.
Regards, Dobias
