Campus Switching and Routing
MTG
Occasional Contributor I
Rename AP fails - ArubaOS 6.4.4.11 - Aruba650-US
Attempting to rename "Aruba_Basement" to "WAP-Front".
Attempt 'Clear'.
AP remains.
Try via 'Provision'.
Change name at bottom of page.
Same name after boot.
Attempt from CLI.
(Aruba650) #ap-rename ap-name "Aruba_Basement" "WAP-Front"
NOTE: For cert RAP ap-name (if specified) in RAP whitelist will take precedence.
(Aruba650) #show audit-trail 1
Feb 22 20:11:14  fpcli: USER:admin@192.168.1.105 COMMAND:<ap-rename ap-name "Aruba_Basement" "WAP-Front" > -- command executed successfully
(Aruba650) #show ap database
AP Database
Name            Group    AP Type  IP Address     Status          Flags  Switch IP    Standby IP
Aruba_Back      default  225      192.168.1.102  Up 22h:43m:35s  2      192.168.1.4  0.0.0.0
Aruba_Basement  default  225      192.168.1.100  Up 2m:39s       2      192.168.1.4  0.0.0.0
Aruba_Spare     default  225      192.168.1.103  Up 22h:57m:0s   2      192.168.1.4  0.0.0.0
Still named "Aruba_Basement".
I have no idea why this is happening.
Re: Rename AP fails - ArubaOS 6.4.4.11 - Aruba650-US
Is it in the Campus AP whitelist?
MTG
Yes it was!
Here are the steps I took to clear it and rename the AP (for others that have this same issue):
Check Campus AP Whitelist.
'Delete' unneeded.
Wait for AP to show up with MAC and no name.
Select and 'Modify'.
Enter new name and description.
Wait for it to reprovision.  Success!
Thank you very much for the quick reply and soluition!
