Campus Switching and Routing
S1500 SFP compatibility
Hi guys,
can you help to check if this SFP part number "GLC-SX-MMD++=” can work with S1500 12p and 24p ARUBA switches.
Re: S1500 SFP compatibility
Compatible SFPs are on the public website:
The SFP you mention is not on that list as far as I can see. However, as it is SFP, it should fit in the S1500.
Aruba does not actively block SFP in the Mobility Access Switches, so it may work. Aruba TAC cannot support the SFP, so if a problem is related (or may be related) to the used SFP, they can ask you to replace the SFP by a supported one. Unfortunately, I don't have such a SFP so I can't test it for you.
Hi hrobers
Great ... Good link ...was really helpful. Yes understand you mean, Btw i ll perform this test as soon as i get test equipment ... then inform you.
Thanks a ton dude for your help ... (Y)
