Campus Switching and Routing
Frequent Contributor II
S1500 "failed to setup connection"
On my MAS S1500's I am SYSLOGging to solarwinds. In these logs, I see a very frequently repeated pair of these messages:
 4/29/2015 11:13 10.110.138.16 Error Apr 29 10:13:55 WB-FOOD-162:PRI-0 activate[1554]: Failed to setup connection
 4/29/2015 11:13 10.110.138.16 Error Apr 29 10:13:55 WB-FOOD-162:PRI-0 activate[1554]: Failed to complete ssl handshake - 1
Any idea why? I searched the boards for this string and didn't see anything. PRI makes me think of voice, but I am doing no voice on this - just plain ol' ethernet data traffic across multiple VLANs.
Aruba
Re: S1500 "failed to setup connection"
That is actually the Mobility Switch trying to reach out to Aruba Activate. If you aren't using it, you can use the following commands and that should disable the messages.
activate-service-firmware
   no enable
While you're at it, you can also disable the aruba-central service which also tries to reach out to Aruba Central.
aruba-central
   no enable
Its been a while since I thought of my old ISDN PRI days but in this instance it actually means PRIMARY.
Best regards,
Madani
Perfect, thanks so much!
