Campus Switching and Routing
Occasional Contributor I
S2500 Power Supply
Has anyone experienced the issue where a S2500 would suddenly power off? Then it would act like you're flipping a switch, it would turn on and off, then on and off, continually until you unplug it.
I've had that happen to two switches so far. I was able to replace one, but now it's happened to a second unit in another building. The odd thing is that the original switch that exhibited this behavior now turns on. It had been sitting unplugged in my office for about a month.
I did remove the cover, yet it looks like replacing the power supply may not be an easy task.
We had to purchase these switches used, so we are already outside of the warranty.
Any thoughts? Does it sound like a failing power supply? Have any of you experienced this issue?
Thank you for your time.
MVP
Re: S2500 Power Supply
If you purchased the switch after July 1, 2014, it is covered under Limited Lifetime Warranty (LLW, http://www.arubanetworks.com/support-services/product-warranties/).
The S2500 does have a built-in power supply, which is not field-replaceable.
I would follow the instructions for the LLW to see if you can have the switch replaced under that.
AFK
Contributor II
Doesn't LLW only apply to the original end user of the switch, ie. the company that first purchased it?
MVP
I believe that correct: The Hardware Limited Lifetime Warranty is provided to the original end user only and is not transferrable.
Did not find information that this switch wasn't at the original buyer.
