Campus Switching and Routing
S3500 Mobility Switch BTU Output?
I am designing a new building and I need to know the BTU output of an S3500 switch - 48P, POE, with 1050W load sharing PSU's.
Re: S3500 Mobility Switch BTU Output?
The S3500-48P with a single PSU will have a maximum of 410 BTU/hr. As most of the dissipation for the second power supply and the load-balancing power supplies will go into PoE, thus the endpoint devices, that will not add to the dissipation in the switch.
If you are planning to purchase these switches, please consult your local HPE Aruba sales team prior, as newer products may be a better choice.
