Campus Switching and Routing
Frequent Contributor I
STP topology change alerts in Airwave
Every so often I see alerts in Airwave that include detail messages like this:
Flushing mac-addresses on GE<#> vlan-id <vlan> due to STP topology change
I'm not sure how to interpret this message since I'm not aware of any STP topology change having taken place.
Anyone have an insight on this?
Re: STP topology change alerts in Airwave
Hi ,
Could you share complete screen shot of system>trigger conditon which is getting triggered and screen shot of system>alerts
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Hi, Pavan - here's the screen shot of the alert showing the triggering event and the condition editing page.
Hi Jon,
Incident happend almost most one month back i.e on 4th April and it very difficult to trace out whether really their is  really change in topology on controller/switch  (ORHS-IDF_A-1)reported VLANs, those logs might got flushed out by now on device.
Pavan
Pavan
Sorry, didn't notice the date. Here's one from today.
Hi Jon,
Airwave tigger alert based on device events which it received, could you check the ORHS-IDF_A-1 device  AMP device events and Device events  section in APs/Device>Montior page whether any entry related to topology change during the time when airwave triggered alert, if we have log entries then I would recommand to open AOS TAC to look in to this issue on device side.
Pavan
Pavan
Here's a shot of some of the events preceding the alert. I don't think I see anything that's specifically related to topology changes.
Syslog is sent from that particular device, I would recommand to open AOS TAC ticket to look in to this issue. In Airwave we cant do much on this issue, since syslog triggered from device based on this Airwave triggered alert.
Pavan
If my post address your query, give kudos:)
Pavan
I've troubleshooted alot of STP issues in the past.
Just to share my experience, I've encountered multiple TCN (Topology Change Notifications), and I've traced based on the ports that initiated the TCN. In this ocassion, I've access 3 to 4 switches and traced the TCN source to an access port on VLAN 2 was wrongly connected to a port in VLAN 8 connected to a Cisco switch running PVST. Unexpected results cause TCN constantly being alerted.
So, I'm curious, where does this port GE1/0/46 go to? A workstation/server, another switch? If it is a switch, can you check if there is a TCN there too?
