Campus Switching and Routing
Split tunnel mode on MAS like Remote AP
Hi all,
One of my customer's requirement is to split-tunnel mode on MAS like a Remote AP. Controller and MAS are connected over Internet. MAS has tunneled-node configured with Controller, which means all ingress traffic would be tunnelled to controller.
But, customer want to send only traffic destined to Vlans in Data center and rest locally Bridged, like split-tunnel on RAP.
Please let me know if this is possible with RAP.
I have tried configuring IPSec and L3 GRE between controller and MAS, untrusted the GRE on Controller.
Client is falling in user-table, but it is not listed as wired.
Any suggestion would be really appreciated.
Thanks in advance.
Karthikeyan Mookkandi
Re: Split tunnel mode on MAS like Remote AP
correction.  Please let me know if above setup is possible on MAS
You would use the MAS as an L3 switch and create the appropriate routes in the routing table.
Tim
Tim Cappalli | Aruba Security
Hi Tim,
Thank you for the response. But the problem is same Vlan exists on controller and MAS.
