Campus Switching and Routing
Switch configuration and integration in Central
I have configured some 2930F devices and now I would like to know if I integrate those devices for management through Aruba Central, the existing configuration will be overwritten. In that case, is it possible to restore some parameters directly in CLI ?
Many thanks & best regards,
Franck
Re: Switch configuration and integration in Central
One of the options is using Template Groups.
template example:
%_sys_template_header%
%_sys_module_command%
hostname %_sys_hostname%
no cwmp enable
aruba-central enable
include-credentials
snmpv3 engineid %_sys_snmpv3_engineid%
vlan 1
name "DEFAULT_VLAN"
untagged 1-10
ip address dhcp-bootp
exit
vlan 100
name "VLAN100"
tagged 1
no ip address
exit
Other option is to add cli config through snippets.
I see but now it is not required to put following command :
I think I'm gonna save config, erase swith, integrate in Central then try reproduce CLI config in central.
Many thanks.
