Campus Switching and Routing
Switch stack member down, client lose connection
Hi!
I have a stack with four members (S1500).
When the primary member is down, the client who is connect to third stack member is lose connection (5-10 ping lost).
It's a normal operation? When a stacking member is down, the clients who connect to other switch in stack lose connection some second?
Switch configuration:
stack-profile
member-id 0 serial-number "XXX" role primary-capable
member-id 1 serial-number "XXY" role primary-capable
member-id 2 serial-number "XXZ" role line-card
member-id 3 serial-number "XXI" role line-card
add stacking interface stack 0/46
add stacking interface stack 0/47
Aruba
Re: Switch stack member down, client lose connection
Yes, this is expected behavior. When the PRIMARY member goes down, the SECONDARY will take its place. This process requires resyncronization of protocols suchs as STP and OSPF which will cause a momentary outage.
Best regards,
Madani
Hi Madani,
thanks for your reply. When I test linecard member down, i found 1 ping lose, but after the same linecard member is boot up 5-10 ping lose.
In this case why was "long" downtime?
Kalman
Aruba
Can you give more details on the stack topology (show stacking members and show stacking topology), where you're pinging (client to client within the stack, out an uplink, etc) and which member you are taking down. Depending on the member going down, it can be in the traffic path and so there has to be a re-route through the stack links, or it could be causing a STP event if portfast isn't enabled. There are a number of variables here.
Best regards,
Madani
Hi Madani,
Please see the attachments! (network topology, stack informations).
swich configured:
spanning-tree
mode pvst
the clients ports set:
bpdugard
portfast
The problem is : when the stack member 3 down, 1 ping lose on the clients (it's no problem), and when boot up 5-10 ping lose (it's the problem)!  Can I configure something, which reduce this downtime?
Kalman
