Campus Switching and Routing
Occasional Contributor I
TFTP Not working Aruba 3180M
I am having trouble uploading images via TFTP.
I have 2 switches on the same broadcast network and set switch_A (ip=10.1.1.1/24 as a tftp server (tft server listen both) and switch_B (ip=10.1.1.2/24 as a tftp client.
When i execute a:
copy tftp flash 10.1.1.1 KB_16.02.0008.swi secondary
i get the following:
The secondary image will be deleted.
Continue (y/n)? y
Error in sending rq message.  Exceeded 5 retransmits.
000M Peer unreachable.
Both switches can ping each other but confused as to why TFTP is failing.
Re: TFTP Not working Aruba 3180M
Hi kainfs,
Try with the command "copy tftp flash 10.1.1.1 KB_16_02_0008.swi secondary" - It needs the whole filename.
Justin
sorry I did type in the full image name originally. I forgot to include it in my original post.
I've now edited my original post.
Any output in the "show log tftp" command?
The file name in your original post shows "KB_16.02.0008.swi".
Can you confirm that you're putting "KB_16_02_0008.swi" as the file name in the tftp command?
They should be underscores in the file name, not periods.
yes they are underscores.
I should have copied directly from the switch.
This is the actual command i typed and the resulting output:
Switch_B# copy tftp flash 10.1.1.1 KB_16_02_0008.swi secondary
Continue (y/n)? y
The message in the Show log tftp
states :
W 03/05/18 14:21:36 00136 tftp: ST1-CMDR: Connection to 10.1.1.1 failed
Would it be possible to show both switch configurations?
@kainfs wrote:
Continue (y/n)? y
I've now changed the tftp server to listen on the data plane only on Switch_A.
I then run the following on Switch_B:
This time I get 000M transport error.
The tftp log gives:
W 03/06/18 08:02:36 00132 tftp: ST1-CMDR: RCVD error:1, msg: File not found.
Sh flash on Switch_A shows the image:
Image             Size (bytes) Date     Version
Primary Image    :33116392 12/22/17 KB.16.04.0011
Secondary Image  :24407181 07/05/16 KB.16.02.0008
@kainfswrote:
Continue (y/n)? y
Unfortunately i'm not allowed to post config. Is their certian portiosn of the config you are intrested in?
