Campus Switching and Routing
Occasional Contributor I
TFTP Problems 2530 and 2930F
I'm having problems to TFTP image files using a 2530 switch.
My TFTP server is located on another subnet.
If I TFTP from my Cisco switches on the same network, it's working fine.
However, I actually can TFTP configuration files using the 2530.
Is this a software bug?
HP-2530-8G-PoEP# show system information
Status and Counters - General System Information
System Name : HP-2530-8G-PoEP
System Contact :
System Location :
MAC Age Time (sec) : 300
Time Zone : 0
Daylight Time Rule : None
Software revision : YA.16.05.0004 Base MAC Addr : e0071b-340ca0
ROM Version : YA.15.20 Serial Number : CN68FP53DN
Up Time : 18 hours Memory - Total : 67,108,864
CPU Util (%) : 1 Free : 39,058,240
IP Mgmt - Pkts Rx : 27,512 Packet - Total : 3022
Pkts Tx : 27,407 Buffers Free : 2895
Lowest : 2884
Missed : 0
HP-2530-8G-PoEP# copy tftp config new_config.cfg 172.18.20.51 J9774A.cfg
HP-2530-8G-PoEP#
HP-2530-8G-PoEP# show config
config
new_config.cfg
HP-2530-8G-PoEP# copy tftp flash 172.18.20.51 YA_16_04_0011.swi secondary
The secondary image will be deleted.
Continue (y/n)? y
000M Request failed.
HP-2530-8G-PoEP#
HP-2530-8G-PoEP# show log -r
Keys: W=Warning I=Information
M=Major D=Debug E=Error
---- Reverse event Log listing: Events Since Boot ----
W 01/01/90 18:31:15 00137 tftp: Request failed.
Thanks!
Oscar Bengtsson
Re: TFTP Problems 2530 and 2930F
Is there any logging on the TFTP server?
I'm using atftp, the output shows that there is actually being blocks transfered but then it stops. Tried changing block sizes back and forth.
Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: Creating new socket: 172.18.20.51:58760
Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: Serving YA_16_05_0004.swi to 10.202.0.10:3150
Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: received RRQ <filename: YA_16_05_0004.swi, mode: octet, blksize: 1416>
Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: blksize option -> 1416
Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: sent OACK <blksize: 1416>
Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: received ACK <block: 0>
Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: sent DATA <block: 1, size 1416>
Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: received ACK <block: 1>
Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: sent DATA <block: 2, size 1416>
Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: timeout: retrying...
Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: sent DATA <block: 2, size 1416>
Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: recvmsg: Connection refused
Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: tftpd_file.c: 979: recvfrom: Connection refused
Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: Aborting transfer
Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: Server thread exiting
Jan 26 11:51:33 KST-LAB-TFTP-SERVER atftpd[2864]: socket may listen on any address, including broadcast
Worked when using tftpd64 on my windows machine, no idea why it doesn't work on Ubuntu.
